As above it’s all the same on the tool set up is there other rules to use as per material thickness i’m having a proble cutting all the way through on materiel
pierce height and pierce delay are 2 separate values but you’d want your pierce delay a lil longer for thicker stuff. run some straight line cuts with different delays to find out which one pierces all the way through. start with around .8 secs.
Thanks i will give it a shot and see what happens
