I draw up a part in fusion and bring it into Sheetcam. I want to only cut a radius out of one corner of the part. Sheetcam Selects the whole perimeter. Is there a way to de-select or select only part of the outside perimeter?
You can select complete contours and move then try another layer for cutting. I’m not aware of any way to only cut part of a contour.
Simple workaround, have your lead-in start just before the curve, then have Fireshare only do the gcode lines for the corner, if need be just hit stop while cutting to end the cut.
It would be nice to do what I understand stand you want. I don’t believe there is a easy button for it. Your best bet is to maybe just redraw your contour or just edit the codes. A picture of what you are wanting and a explanation of why may help us figure a workaround.
I think I have figured out how to do it. I can just sketch a line on a model and and create a dxf from the individual line sketch.
