Anybody have any good cutting parameters for cutting 1/4 steel with the Hypotherm 65 Sync. Every time I run a program it welds itself back to the plate. Any suggestions? Thanks
What consumables pack are you using? What settings did you try? There should be a cut chart in your manual.
100 IPM, Peirce delay 0.3 Sec, cut height 0.125in,
How thick is your material. Do you have a moisture issue? How much cutting on these consumables? Are you using the 65 amp 45 amp?
