I’m trying to connect up a P80 machine torch to my Miller Spectrum 2060 and having some issues.
I have my Langmuir system setup and working pretty well with the original hand torch that came with the Miller. Torch control is being done by the Langmuir and is able to turn it on and off.
Today I tried to hook up the Panasonic type P80 torch (I’m fed up of buying the expensive Miller consumables and wanted something cheaper), and had major problems getting the torch to even fire at all.
I bypassed the tip change sensor via the original miller Torch connector, so that the machine thinks it’s “ready”, as proven by green “ready” light on the front panel.
I figured out that I had to run some wires from the machine to the actual torch copper air line at the P80 machine torch itself, because the Miller does not send current through the air line like the P80 does.
Connected the pilot arc line to the pilot arc red wire on the Miller torch connector at the machine
Torch does not fire at all, unless you try to jump start it by touching a wire between the torch and the work piece, or by touching the work piece to the torch itself, and even when doing that, it will not cut steel, it acts like it does when it has a bad ground and just scrapes the surface.
When I press “torch on” in Mach, relay clicks in the Miller, and nothing happens. When I click the button again to “stop” the torch, the air is turned on by the Miller for about 5 seconds, as a sort of post purge that it normally does. No idea why it completely kills the air when I try to turn the torch on, but when turning it off it does post flow the air.
Oh ok I see. So is there not a way to modify the P80 to function like the Miller torch? Is it the way the arc is started? How does the blow back touch work exactly?
I have opened up the Miller torch and I set up the P80 exactly like the Miller inside, not sure what other magic trickery they’re doing with it.
@Sugarkryptonite
just to let you know that Mecahin416 is our resident Plasma Guru…he has a shop that sells and repairs all things plasma…
as for the difference…from a google search on the web…
-Early plasma torch designs used a high frequency discharge (think of the energy used to fire a spark plug in a gas engine) to ionize the plasma forming gas (either nitrogen or air in early systems) to allow the DC arc to transfer to the material being cut. With these torches the operator had to move the torch very close to, or even make contact with the material. These systems had a hard time getting the arc to start when the material surface was dirty, corroded or painted. You can still buy imported plasma cutters with contact or scratch start technology…very cheap and almost useless! They should not be used on any cnc machine that uses a laptop or PC as the controller as the high frequency discharge will cause electrical noise interference and possible damage to the computer and electronics.
The major manufacturers (in the late 1960’s) then developed high frequency - pilot arc circuitry that allowed a strong pilot arc that would fire the torch without being in close proximity to the plate. This used a strong high frequency discharge inside the torch that ionized the gas, allowing a pilot arc that would transfer to the material regardless of dirt, rust or paint. These systems were widely used for hand held as well as mechanized cutting applications. On cnc machines there had to be careful grounding as well as isolation to protect the system cnc controller from damage caused by the high frequency and its electrical noise emission.
In the early 1990’s Hypertherm developed the first air plasma torch that had a strong pilot arc that could transfer to the metal regardless of surface condition, yet did not use a high frequency discharge to ionize the gas. This technology was called Blow Back start technology and was patented by Hypertherm. For hand cutting this made for a lighter and smaller power supply, and eliminated a lot of internal circuitry that was necessary with high frequency start plasma cutters. This technology allowed Hypertherm (relatively small in the 90’s!) to become the largest producers of plasma cutters in the world.
Blowback start uses a moving, spring loaded electrode that “blows back” away from the nozzle at the beginning of each cut cycle using the cutting air pressure to make the electrode move against the spring force. Early designs had a spring loaded plunger, the newest Hypertherm torch has a spring mounted on the electrode (better reliability over time). This technology (no high frequency) allowed for a new wave of lower cost cnc plasma cutting machines that could be driven by standard office computers and laptops (as opposed to high cost / complexity cnc controllers designed to work with high frequency start plasma cutters)
Just to confirm with you guys and @mechanic416, would a P80 torch work with a Primeweld CUT60 by any chance? Or do you absolutely need their machine torch? I see the CUT60 also uses a “blowback” style torch, but it is a much newer model than my Miller. I ordered a CUT60 and will sell my Miller instead (consumables cost way too much with the Miller).
Hmm okay. What makes it not compatible with a Langmuir system? I just have a regular base model Crossfire running Mach with no THC at the moment. I am still able to return the torch to Amazon, was just curious is all.
The high frequency machine that would be able to use this torch produces a high frequency field(ionizes the air) so the arc can more easily jump the gap between the electrode and the sheet.
This high frequency produces a lot of electromagnetic interference which interferes with the operation of the electronics.
I posted a video on this forum once that explained it pretty well I’ll see if I can find it.
Found it
The specific part about high frequency is it the 2 minute and 40second Mark of the video.
But the first 4 minutes of this video explains the various types of plasma cutters.
if I am not mistaken the torch uses High Frequency(HF) starting which can cause damage to electronics on the tables…it is one thing Langmuir makes clear…HF is not to be used on crossfire tables…
