I have the Razor weld 30. I was using it last night just fine cutting some 3/16 almost maxed out. Today when I turned the plasma cutter, it powered up but then made a clicking noise and the orange light with the lightning bolt is flashing and the plasma cutter won’t work. I tried this several times and still the same issue. When I plug the 110 pig tail and then into a 110V outlet it powers on fin but I am very limited to how much I can cut before popping the bracket. I plugged it back into the 220v and the same issue. I opened it up and looked only to see nothing obvious.
ANY SUGGESTIONS???
I contact the manufacturer they want me to send it to them.
