I use a magnetic Work clamp, the round style that has a knob to turn on and off. I have started cutting 1/2" and with lots of parts. Some times 50-60 mins worth. I notice that work clamp getting very hot all most to the point of smoking. Has anyone else noticed this on long cuts?
I’ve never had cuts that long in duration and rarely cut metal that thick and my round magnet clamp gets pretty warm. So, yeah, I can see that happening. Make sure you have a really clean connection. I’ve trimmed and re-attached mine twice in the roughly two years I’ve used it. And make sure that contact point is actually able to touch the metal. It may be jumping a gap.
BTW, I solder a lug to the end of my wire to help make a good attachment.
Yes, I rarely cut that long at that high amperage. Maybe a Vise-Grip or a copper C-clamp would be a better choice. Now, I have been heli-arc welding and have had the work clamp smoking.
I did unbolt the cable and cleaned things up awhile back but not sure if it made mu difference.
Now I did have the same thing happen on the ground for my mig welder, I had someone doing a lot of 1/2" welding and told me the clamp was getting pretty hot and smoking. I told them with that amount of heat input that made sense. Later they told me it was really smoking and I just blew it off. Then a few mins later while they were actuality welding I saw the nut on the connection glowing red.
I then decided to cut the lug off and attach a new one with new fasteners and that made huge difference.
So Always take anything I say on here with a grain of salt!![]()
Depending on the type of magnet you could lose magnetic field if it gets too hot. Neodymium is the worst for this effect.
Of course inhaling Acetylene ignited Cigar smoke might not be so good for you either…
It still feels pretty strong to me, but would need to compare to a new one to know for sure.
Well Tom Some people are tougher then others. I think their called a mans man ![]()
I have no doubt that their calling is different from mine. ![]()
i definitly cooked one of those switch magnets on half inch plate and went back to brass clamps
