Hey everyone, it’s been a while since I needed help here. My setup has been so plug-and-play that I never really took the time to learn Mach3 beyond the basics. Here’s what’s going on:
I’ve been using Fusion to post-process into Mach3 for 6 years without any issues. Now, when I opened my computer, Mach3 looks different. The buttons are bigger and some things seem off, but it’s not an entirely new program.
The problem: when I load any old or new G-code, Mach3 sees the code as a massive file. The table view only shows less than 1/3 of the actual G-code. Also, the G-code displays as a shaded box with no design lines.
That’s one issue. Another is that my feed rate defaults to 0.24. I can override it and push it to 0.50, but that only applies to micro-movements, not the typical 19-39 IPM I’m used to.
My jog speed had the same issue, but I fixed that by adjusting the motor tuning. However, the feed rate still defaults to 0.24.
I found a forum that mentioned the 0.24 feed rate issue, but the thread ended with someone saying it must be in the G-code. My feed speed settings are correct in the post-process, so I’m not sure what’s causing it.
Since everything worked fine before, I uninstalled Mach3, downloaded a fresh copy, and reinstalled it along with the CrossFire profiles like a first-time setup. Now, the feed rate seems okay, but the file still shows up as a huge shadowed box with no lines in the display.
For example, I have a file with four 2” tabs and 1/2” holes nested together. When I ran it, instead of cutting a 1/2” hole, it created a 12” hole.
I know I should probably upgrade to the FireControl system and be done with Mach3, but I need to make parts to afford the $750 upgrade.
Does anyone know Mach3 well enough to figure out what I’m missing? There’s got to be some settings I’ve overlooked. Any help would be greatly appreciated!
