I’ve had my Pro for about 3 years now, no THC problems until the last couple projects. I followed the troubleshooting guide and found ye old USB ground shorted to the frame problem. I’ve been using a mini PC without issue for 8 months, its power supply wall wart doesn’t have ground plug, it’s frame and shielding kind of float (required for the THC to function correctly). Checked Cut45 voltage output, divider voltage output, cables etc. All looks good. But 0.0V, for live test. While checking the resistance between USB shield and frame, I started unplugging cables. Found that my touchscreen HDMI caused the short. Huh? It’s worked for 8 months without an issue, now nothing.
Long story short, I made a super stiff monitor mount from a Dish TV antenna mount 8 months ago. With constant rotating, rubbed the paint off and this connected the monitor frame to the machine frame, shorting the HDMI shield to the frame and hence the mini PC USB shield to the frame, killing the THC voltage. I hope this makes sense.
I’ll figure out an isolation fix this weekend and get back to work.
