Not matching gcode?
There are only 3 parameters per axis so you can just transcribe them. They are:
Steps Per: , Velocity:, and Acceleration:
You can reach them by opening Mach3, click on Config>Motor Tuning tab. You’ll see a button for each axis, we only care about X & Y.
You can install Mach3 on as many machines as you want, but with each installation you need to copy the license file. The name of the file is “Mach1Lic.dat” and it will be in the C:/Mach3 folder. Copy that file into your new installation.
