Not getting the right voltage
I’ve been having voltage issues ever since I put the table together I think I’ve narrowed it down to the plasma cutters 50:1 voltage port. My live volts in fire control are 0 but the torch can manually fire. When I put a dmm up to the port it never got over .5.
@langmuirsystems
well we could all help if you provided a few details…
what plasma cutter are you using…
Razor weld cut 45
Has it ever worked correctly? Some Razorweld machines had the torch fire and divided voltage ports switched. If you can’t fire the torch from Firecontrol, try switching the wires to the torch firing port and the divided voltage port.
