afternoon to all I have the crossfire set up using sheetcam with Mach3 everything seems to work well but when I make a first cut is the it won’t cut all the way around then when I deleted the holes so I can put them in later it did the same thing it stops before it finishes his pass
Tom
Hey Tom,
What is your pierce delay set at?
It appears you have the Mach3 glitch, search
" millisecond " in this forum and you will find how to turn Mach3 over to milliseconds mode instead of seconds and all your troubles will go away.
I don’t understand it but @jamesdhatch fixed my machine for me.
Where did you get the control
@Andy1601 … A quick search for “Mach3 Pendant” on Amazon or Ebay will get you some results… I’m not seeing them for $25 bux anymore unfortunately!!
What’s model number if it has one?
