I have installed most of my new air drying system. I needed to cut out a bracket for my new desiccant air dryer. Keep in mind it has been about 3 weeks since I fired this thing up.
- I have good air pressure to the Everlast 62i. It shows the correct air pressure on the front panel (77psi)
- I removed the solenoid and cleaned it (i did this because I have been running wet/dirty air through it up until this point)
- I stretched out the spring a little (it started a little under 3/4in, was still under 1in when I finished)
- reassembled
I hook everything up and go to test the torch. No air is coming out. I try the air test on the plasma cutter, and nothing happens. I tried it with the hand torch and again nothing happens. I can hear the on/off switch triggering in the cutter.
It’s gotta be the solenoid, right? Nothing else has been touched in the cutter.
If I over stretched the spring (the thing I’m worried about) would this prevent the air from making it through the machine?
