Hello! I followed the Fusion CAD / CAM tutorials on the Crossfire website for my first test cut. It cuts the hole first then transitions to the main outline. The issue is the the streak that it leaves when moving between the two cuts. Any advice? Thanks!
Which cutter do you have? on the front on most is a setting for 2T/4T. should be on 2T
If you have a Razorweld, the top light should be lit on the setting circled in this picture. The machine in the picture is set wrong.
Yes, I do have a Razorweld. I will double check that setting on my next cut. Thanks!
