What are you planning on cutting? signs like 16ga or more heavy duty items like car parts in thicker material. this will be helpful information for others that run a X45 torch
Anything from 16 ga sheet metal up to 1/8” plate for the most part.Signs and art pieces.Maybe the odd small piece with 1/4” or 3/8” plate for car parts,brackets and suspension tabs
I was looking at the items available in the Langmuir store I believe there was 5 pieces.Should I be ordering all 5 components or are the only a few pieces that will need replacement after I use it for a while
I have very minimal plasma cutter experience,certainly not enough that I every had to worry about torch maintenance.
This is will last you a little while. Spend a night reading other postings on Moisture issues. I would recommend at least a moisture trap, then motorguard M60 filter, and Tru-flate dessicant filter. Some people really build some extravagant systems. You’ll have issues if you don’t have something. It’s tough at first getting going but stick with it. it gets much easier the more you cut and do.
When I stocked up I ordered 5 nozzles, 5 electrodes, 2 shields, and one extra swirl ring. I got the Hypertherm T45 ones from Baker Gas because at the time Langmuir was out of stock. They have worked flawlessly.
