I just bought a used Crossfire with a firecontrol box. Yay! The good news it it jogs just fine. The bad news is I didn’t get the cables for the plasma cutter. I can make them if I can source the connectors that mate with the ones on the control box. Anyone have part numbers or sources for the Torch on/off, the THS and the IHS? Thanks!
If i remember correctly the torch on off connector is a 5.5 x 2.1 mm coaxial plug. The thc and ihs should be 12mm aircraft connectors. All should be available from Amazon.
Not sure what kind of plasma cutter you’re hooking up but contact Langmuir. this might give you some information…
Hypertherm CPC Cable for CrossFire CNC Machines – Langmuir Systems
Sorry, I failed to mention I put is a support request asking about the connectors. Haven’t heard back yet. The plasma is a Lotos LTP5500D CNC. It has the appropriate connectors.
Thanks! I’ll look on Amazon.
@TomWS uses that machine.
As @Midnight_machinist stated, it is the the 5.5 mm x 2.1 mm connector that is sometimes referred to as barrel connectors. Commonly used with security cameras.
Here is a link on Amazon to one that I have purchased (of course, you need different connectors at some locations. This would just be an extension.)
DC 12V Power Adapter Extension Cord Cable 10ft (3m) 18AWG 2.1mm x 5.5mm Male to Female Plug for CCTV Security Surveillance IP Cameras, DVR, LED Light Strip, Max Load 10A https://a.co/d/8hhFcaQ
Thanks, I ordered connectors from Amazon.
