So everything was working perfectly for the first 2 days, but now all of a sudden it won’t start the arc.
I’m super bummed out because I’m not sure whats wrong.
Things I’ve tried…
Connecting the ground directly to the metal.
Manually firing and touching the tip to the metal to start arc with no luck.
Manually firing in Mach 3.
Someone mentioned it might be from water splashing in the torch, but it’s been sitting for 24 hours now so it should be dry.
I haven’t tried replacing consumables because I don’t know where to find them but they don’t look that bad and it’s barely been used.
