I’ve for the machine torch, RW45, water table and THC.
I’m cutting exclusively 20GA galvanized.
Firecontrol shows a counter for time spent cutting.
How long in hours should I get from a set of consumables?
Thanks,
Tim
Thanks,
Tim
That can be from a few cuts and pierces to maybe as high 700-800. It depends on many many factors.
To get the best life here are 3 big ones and I am sure others will add to this list
Clean dry air
Correct cut settings
Quality consumables
you can search on here (top right corner) and find enough info on consumables to read for a lifetime!
What I am slowly learning having heard it a thousand times and the biggest key to long consumable life is
@DnKFab hit it on the nail. I know there are some people that believe that air does not matter but it truly does. Water exploding into steam packs a lot of force. If any doubt as to force water expands 1600 times larger in volume. All of that force erodes the tips. Think of it as a water jet cutter with its target on your consumables.
Also using quality consumables will help.
Yes @mechanic416 I get at least twice the life using George’s aka mechanic416 here on the forums consumables vs the cheaper ones on eBay.
