New ArcCaptain Plasma Cutter Compatability
Hi all, new here as well as CNC Tables. I’m interested in buying a Crossfire Pro table. I’m interested in using Arccaptain CUT55 MP Non-HF Non-Touch Pilot Arc Plasma Cutter with the table… Anyone have this combo? Is it a plug and play type of connection or do you have to do some wiring?
Thanks
A side note: I was typing this out, right after I sent a message to support asking if it was compatible (They replied it should work as it is Non-HF) and they responded in about 10 minutes and that was before they were suppose to be open. All I can say is WOW, great customer service..
It looks like it will work. The torch would be my only concern—the pictures of the torch show gouging consumables. It would have to be hooked up to RAW voltage for the table. Plus, the trigger wires would need to be found inside to hook it up to the table. If you own it then there you go. If you are considering it, then look elsewhere. Just my two cents
@HYDRe welcome to the forum
It only comes with a 10-ft torch whip which is going to be a pain in the ass
If you want an inexpensive plasma cutter by Everlast
Appreciate the input. Very new to all of this so learning. Not sure if it has other tip options. I’m bootstrapping to get up and running and using this to prototype and possibly small production before sending off to have parts laser cut. I have an Arccaptain HF start in my shop now and for the price their Non-HF are very attractive, Hoe about this one? Arccaptain CUT55 NON-HF Plasma Cutter with Smart Display and Mesh Mode.
Or do I just bite the bullet and order the Razorweld 45 and send it? Roughly $1000 more but at this point, time is money. Any happy or sad comments welcome with the Pro/Razorweld 45 combo..
That or the Everlast. Money well spent.
Everlast 62i cnc package would be your best bet over the Razorweld45.
