Wondering if anyone has ran across any new nesting software?
Late answer, but the thread is still open and I had the same question a year ago, which is partly why I ended up building one. Disclosure first: CutYield is mine.
Options I know of that are not SheetCAM-money:
- Deepnest (desktop, free, open source). Does true-shape nesting from DXF/SVG. Still works, but development has been quiet for years and it is fiddly to install on a new Windows machine.
- SheetCAM’s built-in nesting if you already own it. Not free, but you already paid.
- CutYield (cutyield.com), the one I built. Free, runs in the browser, nothing to install, no account. Import a DXF, pick the layers, set your kerf as the beam width and a part gap, choose whether parts may rotate (none / 90° / 45°), give it a few seconds, and export the nested sheet back out as DXF for FireControl or SheetCAM. It also does plain rectangle cut lists for sheet goods, which is what most of the woodworking users are there for.
Honest limits: it is a nesting step, not CAM; it will not do lead-ins or cut order, so the nested DXF still goes through your normal CAM. If you try it and something imports at the wrong size, that is almost always the DXF’s units header, and I would like to hear about it.
Anyone else heard of this?
Thanks for sharing these options. Deepnest is the one I have seen mentioned most often for free true-shape nesting, though I have also heard it can be fiddly to set up at first. The browser option sounds handy for a quick try without installing anything, especially if the nested DXF still goes through the usual CAM steps afterwards. Has anyone here actually run a nested sheet from it through a full cut yet? I would be interested to hear how the part gaps and kerf worked out in practice.
Fair question, and the honest answer is probably not: it is new and small, so I would not expect anyone here to have run across it yet. It is free, I built it, and there is nothing to sign up for, so the quickest way to judge it is to drop one of your own DXFs in and see whether the nest comes out usable on your table. If it does not, say so here and I will fix what broke.
Honest answer: nobody has reported a full cut back to me yet, so I have no real-world numbers to give you. What I can tell you is how it is set up. There is a kerf field (your beam width) and a part spacing field for extra gap between parts, and the layout keeps that room between the outlines. CutYield only places the parts and writes the nested DXF, it does not make toolpaths, so the actual kerf compensation still happens in your CAM as usual; the spacing just makes sure there is room for it. If anyone does run one through, I would like to hear how it went, good or bad.
