Morning all, I am frusterated with fusion 360. I made a sign and have some questions about editing, resizing and moving objects.
couple things first. I think it would help if you could see the sign so its easier for me to tell you what i am having problems with. not sure I can do? cattle company sign v1.f3d (136.2 KB)
see if you can see this file?
Not sure if this is the right place for this topic?
To resize hit the s key to bring up the search bar then hit the s key again and find scale from the list. Then select the sketch geometry that you want to resize.
To move geometry hit the m key which brings up the move menu select the geometry you want to move and relocate it.
I know this is pretty general but if you add some specifics I can get more specific.
Thanks for the response. First how or can I move the cow/calf inside the sign so the cows butt is touching the half circle? Instead of the nose.
2. the sign is over all to large of a dimension is it possible to reduce the size of the sign while keeping the ratio of the objects the same. and how to do it?
3. I think i figured out text editing. but when you come across for example O and A’s how do you outline the centers so the plasma cutter knows to cut them out?
I have more questions but i’ll ask after I get a handle on these. I am on overload. LOL
thanks I got question 2 and 3 fixed I think. cant seem to move just the cow and calf inside the sign. and still wondering about how cutting the holes in the letter. yes when you get a chance. I appreciate your time immensely. thank you
I bet I could design this sign and do the cam in under 30 minutes from scratch using Fusion 360 with the provided cow SVG. If I had to trace the cow from a canvas in fusion 360 maybe 40 minutes total.
I’m sure someone with inkscape and Sheet cam with their flow dialed in could do it in that amount of time too.
I do wish they had options for Fusion that would hide all the erroneous tools and menus for a beginner.
Very well done. OP you should probably make some changes to the thickness of the arch to give the letters some strength. Unless you’re doing them as an additional layer.
@TinWhisperer we need to get the “Rosetta stone” project up and running. Show how to do a design across platforms. Lol
Yes, great catch. Learning a little bit every day. I am finding out there is many different ways to do things. I am definitley do things in an inefficient way. thanks for the help.
Me neath… I just cant find any other Cad we can use to make things… And havent even tryed inkscape yet. I just know the basics of Fusion to build simple parts and edit drawings that I found on the internet…
