not sure what might be causing it but my cuts are getting beveled. new tip, new electrode, cord doesnt seem to be hanging up. and my THC movement doesnt seem to be binding up and its adjusted as tight i can without deflecting the guide rails. my torch height is also very far off, smart voltage is at 98V and it runs all over the place, in sheet cam i get my cut height to .06
tap file:
36 ford leaf hanger sides 2 single.tap (1020 Bytes)
here is the gcode produced by sheetcam
(v1.6-sc)
G90 G94
G17
G20 (Units: Inches)
H0
G0 X1.7391 Y2.7751
G92 Z0.
G38.2 Z-5.0 F100.0
G38.4 Z0.5 F20.0
G92 Z0.0
G0 Z0.02 (IHS Backlash)
G92 Z0.0
G0 Z0.118 (Pierce Height)
M3
G4 P0.8
G1 Z0.06 F55.0 (Cut Height)
H1
G3 X1.7391 Y2.9561 I-0.0905 J0.0905 F45.0
G3 X1.5326 Y3.0417 I-0.2065 J-0.2065 F29.25
G3 X1.2406 Y2.7497 I0.0 J-0.292
G3 X1.5326 Y2.4577 I0.292 J0.0
G3 X1.8246 Y2.7497 I0.0 J0.292
G3 X1.7391 Y2.9561 I-0.292 J0.0
G3 X1.5581 Y2.9561 I-0.0905 J-0.0905 F45.0
H0
M5
G4 P0.5
G0 Z1.0
G0 X2.658 Y3.828
G92 Z0.
G38.2 Z-5.0 F100.0
G38.4 Z0.5 F20.0
G92 Z0.0
G92 Z0.0
M3
G4 P0.8
H1
G1 F45.0
G3 X2.53 Y3.7 I0.0 J-0.128
G1 Y1.8
G2 X2.525 Y1.7834 I-0.03 J0.0
G1 X1.2953 Y-0.0612
G1 X1.3536 Y-0.03
G1 X-0.0675
G1 X-0.03 Y-0.0675
G1 Y5.5675
G1 X-0.0675 Y5.53
G1 X1.3536
G1 X1.2953 Y5.5612
G1 X2.525 Y3.7166
G3 X2.7025 Y3.6811 I0.1065 J0.071
H0
M5
G4 P0.5
G0 Z1.0
M5 M30
(PS45)
What thickness and material are you cutting? 3/8 ?
How are the rest of your consumables? your swirl ring, deflector and retainer have air passages that can’t be obstructed.
You might need to check your backlash to see if that’s what height is actually happened. Maybe its starting too high and that’s where Smartvoltage is sensing.
Basically everything is still brand new. This is my first time changing consumables mainly because I accidentally crashed it. I’m trying to cut 1/4 plate. I’m not entirely sure how to adjust the backlash either.
if you cut a circle, does the bevel follow the circle? or is it beveled on one side and undercut on the other?
Try setting your cut height to .040". This will eliminate the .020" backlash compensation that the post processor adds to the code.
