Where can I get step by step instructions on how to take a program that is not currently ready or processed with a machine three processor and make it cut ready for my cross fire pro I have found that some of the programs that say cut ready won’t work with the cross fire pro or I mean fire control
Langmuir itself has what is called the Software Workflow provided in their website. It discusses the steps from creating a design (CAD), developing the movements that your machine requires (CAM), and utilizing that file (g-code, whether .TAP or .NC) in Firecontrol to cut the actual part.
They include videos of each step as well - you need to watch them if you skipped them.
I have a very basic video as I did it some years ago but others are more thorough like @TinWhisperer and a few others.
But my above summary is pretty much the gist of what you’re asking.
AND it has punctuation, something I’ve found very useful in trying to understand posts!
Sorry I miss spoke I meant off of Langmuir don’t bother helping anymore iam not as perfect as you so take your remarks and I think you no what you can do with them
Langmuir help is useless to say the least if I knew how to use Sheetcam I wouldn’t be asking for help but thanks again Langmuir has useless customer support will never buy from there again because of this forum
Sheetcam has a large user manual. I actually printed it and had it bound when first leaning SheetCam. You will have to put in some effort to learn this. Your other option would be to use Fusion 360 and skip SheetCam, since Fusion has the CAM built in.
But, in any case, you will need to do some reading and watch a lot of YouTube videos. None of this is intuitive and there really aren’t a lot of “quick” answers if you don’t invest some learning time.
Learning SheetCAM, Fusion or SolidWorks is not something that can be done with a quick phone call.
I agree, this forum is not a good fit for you!
Won’t see me back here I have learned sheet cam and am still learning all I was trying to do is take a project off of fire share that was not post processed to g-code and post process it to g-code and cut it even sone if the cut ready projects on there are not set up for the cross fire pro they are set up for Mach three but thanks going to stay out of this forum I get the hint
