I’m not at my computer but you’re cutting on the wrong side of the line if that’s your lead in and lead out.
If you go back to the design environment and extrude that profile into a body and then move back to the manufacturing space. Then it is very hard for this mistake to occur when selecting your geometry in the 2D profile menu.
Or you’ll have to go back into your 2D profile where you selected your geometry and click each of the Red arrows so they switch direction.
Having a lead in, lead out, lead-in angle and leadin radius will help with your divots too
the one outside cut was on the wrong side of the line.
The inside divot is on the correct side but on the line but without a lead out it causes the divot.
Which plasma cutter are you using? I saw MTM60 in your tool profile at 40ipm but setup in this profile as 120+/- cut speed 230 lead in /lead out speed ( I know you were not using it for this profile)
Look slike fusion is changing some plasma options since the last up date(purple box)
I reworked the the F3D how I might approach it. I am not sure of the material thickness you are cutting but I set everything to 120ipm. I would consider some feed rate optimization if it is thicker then .125"
