Need Help CrossFire and Titanium 65
Need Help with the Crossfire XR and Titanium 65 Plasma Cutter hookup. What’s the difference between
Raw Voltage and Divided Voltage and how to hook it up please
Jessie from Georgia
@Jesus72 welcome to the forum!
Connect the torch fire wires to pins 3 and 4. Polarity does NOT matter.
You can’t use the divided voltage pins on the CPC port for the Titanium 65 The LS VIM module requires either a 50:1 ratio or raw voltage. Because the According to the manual(see snip below)Titanium 65 outputs a 20:1 ratio. That being the case, for the THC you will need to open up the machine and connect the raw voltage pigtail wires to the lugs inside the machine positive (work clamp) and negative (torch lead).
Checkout this thread linked by @ChelanJim in the other topic you posted under. @TinWhisperer posted a pdf of the manual and some other good info there.
ChelanJim
Sep 2024
