Not sure which software that I’m doing something wrong in or if its setup with the table. But I’m following the tutorials for the bottle opener and decided to put a logo in the middle. I think everything looks good in Fusion 360 but when I transfer the g-code over I can see the lines in Mach 3 that shouldn’t be cut out. I decided to just let it run to see what happens and it only cut a few pieces and didn’t even cut the whole thing. I am also using a Everlast 50s and am wired into the CNC port. Any guidance will be much appreciated and sorry if my lingo is off I’m new to all this. Thanks in advance.
Are you still using the demo version of Mach 3? If so, you are probably more then 500 lines of code with your logo
