when you hit import this pops up
you can change it here
May I ask how you would delete the borders of that image in Inkscape so that when imported into sheetcam the borders would not be cut?
SheetCam doesnât have a lot of editing capability, but what it does have is the ability to cut only certain layers.
SoâŚ
You need to move the contours that you donât want in the output to a new layer and then never use that layer in an operation.
To do this is simple, but may not seem so. Iâll explain, but if you donât get it, I HIGHLY recommend that you watch ArcLight Dynamics tutorial on Contour editing.
In sheetcam you can select various edit operations. Depending on the version youâre using, the tool button has been moved, but you want to âEdit Contoursâ. Find that button and select it. Then hover your mouse over the contours you want to eliminate, click on the contour to select it, right click to get a new menu and select move contour to a NEW layer. Call this layer âhiddenâ or something equally meaningful.
Do this for all the contours you want to remove (move them to the Hidden layer).
Once youâve done this, in the âLayerâ window on the left side, uncheck âHiddenâ. All the layers you want to go away will disappear.
Then cut the rest of it.
Is that John Wayne?
No, John Wayne had one lung. That dude has one eye. Totally different. Ask anybody.
Well, I mean, ask me, Iâll tell ya.
