Down loaded fireshare project and is a NC file, how do I get this so I can use it in fusion 360? This is new to me, Thanks
An .NC file is already a cut file that can be loaded directly into Firecontrol.
If you want to modify the file and the original poster didn’t include a DXF or SVG, you may be able to use a g-code ripper to make it back into a DXF.
thanks! Probably easier to find another image like it thats an svg.
Fusion 360 can use DXF, SVG or f3d files. Fusion 360 will create an .nc file but does not have an easy way to edit it once it is made. That is the g-code file that you ultimately want for FireControl.
Got it, thanks for the lessons! Thanks all!
