My XR is not running at program speed
I have a program written in Fusion 360. it works in simulation but does not run at the posted speed, imp, on the plasma cutter and the torch keeps kicking off. I have made a number of parts previously with no issues. the program has it running at 200imp but it is only operating at 4imp. I have shutdown and restarted the computer and can manually operate at 400imp. I have written the program a number of times and still the same issue
Share the g code and/or F3D file for us to look at.
Also to confirm, not running in metric and expecting inches right?
@chuckra welcome to forum.
You’ll likely have to post a few more times before the option of posting a file opens up for you.
Hello Kwikfab. Thanks for the response. I went over the nc code line by line and finally with the help of a friend determined the issue. First and foremost I had a serious case of really stupid. For some reason the code from Fusion kept posting the wrong feed rate. My friend brought it up and once I corrected it the machine worked like it was meant to.
Thanks for the welcome. A good friend of mine used to post here all the time before he passed. I really enjoy my XR and generally am out in the shop every day working on projects.
So it was as simple as you having put in the wrong feedrate?
It’s ok, we’ve seen stuff like “my plasma cutter won’t cut” for simple things like having left the plasma cutter off, or the air compressor off.
I actually had one of those silly issues. I forgot to connect my ground clamp. However I determined what I did as soon as the torch kicked on.
@chuckra hate to hear about your friend. Good friends are hard to find and can never be replaced. There has been several people over the years disappear from the forum that post often. Make you wonder what happens. Is it to personal to ask who your friends was?
Mac in Texas. I still think about him every day.
