I did not want to bog down yet another topic to update people about my 2020 Limited edition RAM 1500 truck. Which, incidentally, drives like a luxury car.
Summary:
While on vacation over the 4th of July (about 300 miles from home), I heard a pop or clunk sound similar to the belts breaking in a tire. The next day I had a Christmas tree display of alarm lights and messages on the dash and lost many features:
- Electronic Stability Control off/unavailable
- Air Suspension System off/unavailable
- 4WD unavailable
- Steering directed Headlights unavailable
- Start/Stop unavailable (where engine stops when you are at a light and starts quickly when you go.
- Check Engine Light is on
I was able to get an appointment at a dealership nearby but I had to wait 5 days.
They determined: Steering Rack and Steering Control Module should be replaced. The total expected repairs would be $4000. They reset the codes and all systems came back online and the right front tires had excessive wear so they could not do an alignment without new tires. No new tires in the entire town!. But the steering wheel was about 15 degrees from being centered.
Since the Steering rack was back-ordered for 6 weeks, they suggested that I go home. âPerhaps the lights will come back, maybe not.â Within 10 miles all the warnings and loss of systems happened again. I immediately called my local RAM dealership (Port Angeles) but they could not schedule an appointment until Sept. 10 for diagnostic.
By the time I got home, the right front tire was showing the belts/cords/wires (whatever they are called). I did not feel I could drive it until it was fixed. By the 4th week of July, I called the Port Angeles dealership again and pleaded with them and pointed out that I am not able to use the truck. Meanwhile, I got the front tires replaced. Port Angeles RAM dealer says if I bring it in and park it in their lot, they would very likely be able to squeeze it in âin the next two weeks.â I dropped it off on July 25th.
No word for weeks. I called 3 weeks ago and talked with the manager. He sounded as hopeless with the situation as I was âWe had two techs quite the day you dropped your truck off. I am terribly sorry.â
Well, they finally looked at my truck after 6 weeks and tell me first:
- The battery was deadâŚthat was related to some of the codes. (Oh good grief. It sat in their lot for more than six weeks. Who knows what electronics is going off. It is periodically making adjustments of the level/balance suspension 24 hours a dayâŚI hear it doing something).
- They did an alignment.
- They cleared the codes.
- Two different people took it for a test drive (They liked my truckâŚsounds likeâŚperhaps too much!)
- They declared that it was fixed. All it needed was an alignment. Obviously, the clunk I heard/felt WAS the issue.
So it seems to be totally back to normal ![]()
They charged me $380 (which I find to be very reasonable for what they did).
He said they didnât charge for the alignment. That is a two edged sword:
- They had to do the alignment as part of the âdiagnostic charge,â and,
- They did the alignment less than a year ago and I believe they did something wrong or incomplete at the time. Never have I experienced an alignment issue in less than a year unless there was some heavy hit curbs or an accident or very rough roads.
So they owed me that alignment.
Iâm happy. ![]()
