I dont know if anyone has had this issue but im putting it here in case someone runs into the same problem. I was able to download and install the full version license no problem. No matter what I did my name would not appear at the top of the control board and I continued being beat up by the word Demo. Turns out my file was Mach1lic(1).dat and is wrong. It may work if its added to another machine after the original license but the original license install to your mach 3 program has to be Mach1Lic.dat. If anything else appears in it, delete it.
Hope it helps
Correct. That’s caused when you download the same file twice to the same directory. Your browser appends the (1) or (2) or (3) depending on how many times you download it.
You can find the first download and use that or rename it after you copy it to remove the (1).
