I have never worked with or seen a cnc plasma in person.
My first project.
Started with this from the internet
Processed in fusion. Ended up with this
https://dsm01pap003files.storage.live.com/y4mAPVB3q4kCL8E8IH8zt2vc_0x54Gked0d76ryxK2A42IFVVcBq6QRX-3AarKS_e9A-Zb5qMj_UK3B8xDLE0dBhdcYOKadgBpaeVirgSkeQmuqtutJbR1Jrj_FCS_oON4Ai6l_u4_hVs05o8U701O2uKbL_ORCtS2ZeW2s4hOk7ggC_wTBEWMdnbM_1Lxh9MkT?width=3024&height=4032&cropmode=none
Cut from 5/8” mild steel plate
XR with
- Powermax 85
-Air system
- 7.5hp 80 gallon IR compressor
- Desiccant tank
- Norgren 3 stage water separator
- HF refrigerated air dryer
- Water separator/regulator at the table
- Separator at the plasma cutter
- 2 Pneumatic toggle switches for table fill and drain
- 2 quick connect air fittings
https://dsm01pap003files.storage.live.com/y4mC2aQVsdocLFEptJBy8k-tnPaAcgYrwYaWoep8j3GN6d2Qkl_dii_dn8PnND-FYeAswyNrvwsVAbOWiGuWisGTRp4w3xdxhOHn4e9XAEqxlmXhU2JVNcSSuu5tjLYoIEYXIk7CynNSdFaVuFqJfXFwCVZtwjnFdP5AkL61lm_b83kkWa2ruJxMDCA5NxIJxpF?width=3024&height=4032&cropmode=none
https://dsm01pap003files.storage.live.com/y4mVpFrfR2s9V8XOQ1EXZkq1blkW_-YeqJGGAx_G2mZg_jWWAIwzEZDXXGTdJaYC31kMDJkxJfSYITgySDaqcMVTVr1sWNNGJ2YKG5XLxI42q4EmCsupOb1WupiUbgK0DnXcy2uw1YEmQK9MiRc2RiwnISHZ7szTKP1uxOFihrrqCmdckXIY9E4K7QswHyibG4d?width=3024&height=4032&cropmode=none
https://dsm01pap003files.storage.live.com/y4mtPwM-hnAiW3PZCYXgsdlKM2OfhHeLc2tNR4ZqEO_PjpyzGA171priiLBruaqeo1bS5EYY-pGy87dgnyqCmM63EsEGnVTMScyGzG63Ir9ZWfX0WpQf9ndcbzTLroR7j1Z72y__-IzEbp-yecPeu9HHwyd49Lu6CxnKa6GZRzqOj7emAQyEV3HRR4zSX0OCUMb?width=3024&height=4032&cropmode=none
https://dsm01pap003files.storage.live.com/y4m4O8GJfgTLX-hEii0lJwlOAqoMB-sw2IBVBtv4o8CB0WhlMXmnxpQdyr8wiweXRs9t4MQ5UJEW8v687RfePV-YtEYL4v46TCNrpr6VMzYmUp5qVsAUbrsPAbuXXzVd0j2PWn6h_iwEgHOV2OUhjfX2wvDg3UZyf-57I_we2ELx_3Hi49MVCt5JZ-KeK2GUAqS?width=3024&height=4032&cropmode=none
https://dsm01pap003files.storage.live.com/y4mcGAbcx3VxtM9WRSpy1NDIG4QrJtbpEbYLoefmk0tXmH8wAlI3I-FZDumIuYgPqCXssRJnuRE-eG27-dfBt-ejuqO8MfTX39F_N5ZcVH7aK0cpid67m5RBfp3EO--9ZSoaBJLHMzhMSDyGOhUUnFeJU8ZOjGRJzsbQg_k1YDHntmBcs0foY39XG_-KaGPzCSk?width=4032&height=3024&cropmode=none
- Water system 1 1/2" PCV
- 4 drains
- Sediment filter with scotch bright pads in the drain
- 75 gallon RV water tank
- Shut off on the drain and check valve on the fill
https://dsm01pap003files.storage.live.com/y4mmnQkmMjGqKyF8Tytq66b4mx-nWBTVIFwSYYP-k7BXsEHMp-HGsN2nh37SEhItPsZufBexArpDhkSGhyNxpaNYIxhYqq3A8Ddv7ECuFXKOHRbscSkSkW22UTCPsmanBLytl_aywZHxHmD8SBbhZMmhR798_2c6jRKivd6I1kQxts92JtQAG6OMF8LQUO2HxAe?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4maINOmKcMR24nmPjEST0t04p96UfnbiL6-YviiDJeyHkKUpDsAePOWu7RN0YYINVWIjn0Kz9weRqQ1UUJhuJjqYYIJn1jK8fm4Wjj0ffGcVxPmUmFo4xwv3lO7Q1u_6CBS4J3mOnB1ND-ABJomlUDt58G5oVGStilcXbFxGT8F0UdTglEOrYG6zLLOsvsMwSf?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4mtDZIyMA8S2U2HaavQrhZTsQc4a2sJD_quNEgwjKPSvcuh90PtDo6SPDPjvggQ5yQrbZg8e3KmzozjSmltHm2oQhKh5Bvt6YII7SLwBwExxIoK7rYnXNM_sAyALcWb0goUbxF9p62tcr7_GGG5NQyauqwtwhEPqJlrwD_2QoKJF6mOmsUDHrZeorpbpn_BLNN?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4mVyWS0S6HJ-5Qj9Srv6pIW4zGS-V4bhQbusyc1CflhxGsXH5s1yrylJdoaCSqMnlztH5psqqJz1bIhvzGNeD5z_oKAP6hbUj-hx3DYdVrNkwmOdqyXJBp7uRI9sbel1l_vGgLz5P_7A-BmuYcqtVQ9_dYUsjusFWubhMkLj69CZn6zp3wA1Hz5AjVLuZIvZiU?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4mbDWyIm0nSn0VcCPa2LE6G2QSTlGuWYxfUxyCR96P6IiAcJNiHXClUj-5LsMRj4jhU_IBbHeO1rQkkxGcK-20UKaG69kQBm9ONcdRZTrvcF-j43bI5LXvQ_yIfElH7wUt__pnKg5Ee9Dn3ubEN2r891Hy5cpWBYORj-jGLSQnmwB7kp0RRr6O6_mB9OfiHeXY?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4mjduWyYLMG_Jh3CPAzNt6Zk7Jd0gYQ60zx81Cnyn-W-7rdkl46QMUL8r9TKCqRJqtUoAytJ3AC9JdL_8Mare0qd_INjnshuXx3NG32m0FRNbUwIzrsAG0yh7sZwsgIA5gpfTevaqs3cRsnC2ef23XG0D0J4IlW5AsoEUC32ftP8hB_4FT_0EqzTml4lGB3def?width=4032&height=3024&cropmode=none
- Monitor mount from Amazon
- All electrical and air is plumbed to the table then distributed underneath. White cord is left long so I can add a disconnect to the table in the near future.
https://dsm01pap003files.storage.live.com/y4m1sSdS6m5EtD8fZF7nNphQjMK1_8gCul1UKGW5Fuj8-k6_vy4DqFSnoVpFzT8jqYRoWxxzVQ1uXxS_lN2BC52kcz8D4yYl-6YgjRKDvbQrh6EPsdUYPQG_BXd3m0K8kGX2Pt58EFRpHIyYUGn6qilkbmkKMMAaFM1Ggb-LbIIUA5J8b0FVNOfLYQ2h1qOBjeC?width=1170&height=2532&cropmode=none
https://dsm01pap003files.storage.live.com/y4m7NfBYdGspNCtaUSayAolijDaaZKL70pHBBXvDu0F4RR4_FzYPjZJFXFTpbAKvLUlRAoz3FY1Sbb7XS2sC4-ZiXXWpzbV7LOA0XFRRLTir2p4pdwHJpi5Nb-QBQXY35xz-cD_jvI3Gh6n6W7nrLAoToiLvUvGn_BcwzjLtvaAaOuvfYCkxVRDB64au_0skUz4?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4m7w2BO_CuYFDPn7rqC5n8d6h_YYGDl99p3uVRkRTVYftYrmY9ty365LsDxWcw-KqXZMrLJG8pnTwzfZsrKdkruCNoQTMDTlycc-pKJYLR4UMeBhv3euF4GTeDPr37_uP8xHmtV19ixFCD8AOvgq5a3k2DrRqRS8J2h7HvMK81qZbgUvl2IPyow29kHWXsy3EI?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4mImawujkXTbfteaKUtzR9Ib9aK6X4AbYGmYUvzRWXa_1Dzg5n-7Jmkfg4iKNngyRle5qbcKmEEhTHIeKMnkUQPhRTsumvLRgvnqpHxkBDoEfkA8a-X7RLMFs2UuWL-Y4yq5hwJiV4LZQ4zwT3o-OOu_KG-zchi8hgx34QGqhNF4Kh_naJAWY-q1jNOIZCDg_f?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4mCiZ8zT4OdF97fdbikNWOZpRKXx5MTkUZeXdQBhXe6Z5Su_FAk12TaYCugVz9GuvoQ7GMqILPlC8RrxrGzPgqcSlFDlxx6vAi1HQ76aImDmutYdYjH9cXxZMyTVqxzfpK5wQYTV0g1Qfvrnk70Dro9w0myLaDt3oXcBoN1YoDjOfwyh-B8QKW3xtpYKnMzMot?width=4032&height=3024&cropmode=none
- The first cut and some miscellaneous photos
- I need to install some heavier wire and bigger breaker for the cutter. It tripped the breaker a few times cutting the 5/8" plate. Smaller one is 1/8". Need to fine tune it. But for my first cut I am happy with the results
https://dsm01pap003files.storage.live.com/y4m_4_SpuRKz61AoYvWkBfEMWYfldJ-_J2l0NmUyzvUeYkp17ICpF4Efp3JFRThI_TzaQcBI3cfEQHV74yXt4BtnPeKpYGL0bbSW1kyOg6KvTAA8jjlZFNwDYV-QMqW75rJlV_csZIWJVI1-5RONx63DQP2WnWN4twyGDWPRhQ6SCXcIoSLbJQpPta7dp2ShEbI?width=3024&height=4032&cropmode=none
https://dsm01pap003files.storage.live.com/y4m9nPD_uwT7g8OSScoL24U_lboOgXv752XtPLqharitYjtgbv3ipurQAl3ai_vIHjNcO0kbYXfk4lD5qj8mqhnVWOQ1m_ToKze4vgriB6Gmiho3mdsGMcsd5TAQqu_cjm7VBS0CSvTbqI265s9dK91W2JsMHwojz0yOf-fedjzc4bq_SSMkCqcZ3C1yJ1CZ6ct?width=4032&height=3024&cropmode=none
https://dsm01pap003files.storage.live.com/y4mCiqQPdwuTfjYYg7Ljf3CbQbwbAW_WwG9JpQ-xmL4e1w0NvkWc2LS_ipFLQ3Cmd46E1va2tBCITowKSY-c---C9-ViXOF8B_xYsbXjxPGvkW-58fZmUyV7HN16u9UVYirXHUgso_US4trQDBuIZqVkELt6975cnQEEh3YLmA1tQar37bJ7mJfwwQ4ui2jNAbL?width=4032&height=3024&cropmode=none
