This is a 2x2 aluminum sign.
Looks great!, what is the material (thickness, type)?
do you mind sharing your settings?
Thanks! This is 1/8" 6061 aluminum, cut with hypertherm 45xp standard nozzle. 80 IPM, 35 amps, .5 Pierce time. The back was very clean, just light sandpaper to knock a couple points of dross off. I used 220 sandpaper for the brushed finish.
Looks great, how you going to hang it?
I used strong double-sided tape to mount spacers and another piece of aluminum that has mounting holes. I didn’t get a picture of the back but I will update with pictures when the customer hangs the sign.
