what I do is not the same because i’ll make a sheet of mostly diferent parts but sometimes i’ll need 4 or 6 of one of them so it can work too, In design I make a new component and copy all the other components or bodies i want to cut from the one material into the new component and I have that component activated when I go into manufacture. all the nesting I do is done in design. one advantage for me is all the components that are copied in will always be up to date with the original design. That way if I need a little more clearance or have to add a hole or something it’s changed automatically. you can also make tool paths for individual parts instead of cutting the whole thing at once.
