Ive got a through bore in my part from my first operation that im trying to use to zero for my second op. The issue is that when I select the bore for the wcs the orgin is on the top and centered on the bore. This leaves about 0.300 of material above the model not acounted for so the part isnt machined to the specfied thickness. Is there a way to raise Z to the top of the stock while still being centered on the bore?
Ive also tried just using the XYZ corner probe but had issues with the part lining up when flipping for the second op.
