I am fully aware how to move / copy images around my screen but is not working now. Anybody have a fix ??? Seems to be possibly since the recent update But I don’t know. Thanks…
I’ve been using fusion quite steady over the last few days and haven’t run into a problem with move copy.
Is it when you use move copy for sketches or using move copy for bodies?
Is the problem occurring while you’re moving it or while you’re copying it?
And it fails 100% of the time after the update?
Can you post what you are having trouble copying? In the past I have had trouble copying sketches that really node heavy.
It is when in a sketch, I don’t even know what a body is. I put a box around the object ( a simple circle drawn with the circle function ) right click and get the menu and choose move / copy and it sets up the arrows and square and rotate thing but nothing will move as usual. I can go back to things I’ve done in the past and it works fine there. and I have tried several times so the only thing that seems to have changed is the update or what could I be missing ? Thanks…
Read my reply to TinWhisperer please and Thanks.
And today it is working as normal…Am I now remembering something about maintenance on Sunday, maybe that is what was messing with me ?
This circle likely had a center constraint holding its position.
Sometimes constraints are automatically entered depending on how or what you select.
Might also be a fixed constraint if it’s imported SVG.
Check the color of the lines. If they’re green they are fixed. Select them and then click the lock constraint to unlock.
