Anyone on here from the STL area? This place seems like an awesome forum to be a part of. Been reading a lot on here since I’ve joined. Lots of good info. I’m currently waiting on my pro to be delivered.
With that said anyone ever upload files from other places rather than fusion 360 or sheet cam? I’ve got bend tech pro software with sheet metal module I’d like to use. Just curious if anyone else plays with the Bend Tech software/fire control combo.
Correct. FireControl uses G-Code. You need a program to convert the graphical data (DXF, SVG) to G-Code compatible with FireControl. This requires a FireControl post processor in whatever program you use. I would recommend SheetCam because this is it’s only role and it’s very easy to use.
Yes, it’s $10 cheaper at Langmuir than buying direct from SheetCam. Order from Langmuir, they send you a code, and you use that to get a license code from SheetCam. In either case you need to download the SW from SheetCam. The product is called SheetCam TNG.
