I keep getting a “diameter error” and minimum cutting radius issue. I am using a stencil font. Is it claiming the corner is too sharp or something?
Are you creating a program for a mill or are you creating a program for a plasma.
If you’re creating a program for a plasma then you’ve used the wrong machine in your setup.
If you’re creating a program for a mill you would want to use a smaller tool to get into those tighter diameters
Plasma of course. Using the same tool in the library I always had. Fusion looks a little different than normal perhaps it updated?
Well it definitely wasn’t set on cutting in my first setup for some reason. Lol thanks anyway let’s see if that doesn’t do the trick
