what is the distance between the bottom of the water pan and the floor and also the distance between the floor and the horizontal bars near the bottom of the legs. @langmuirsystems
Thanks!
Thanks!
anyone? trying to see if my water storage tank will fit under table as well as my lift will roll under the lower horizontal braces. @langmuirsystems
I’m trying to figure out the same thing. Looking at the numbers they have out so far the floor to top of water table is 3.0’. The water table is 3.4" deep. That tells you close to what size you can have under it but not what size will slide under the table once assembled. The frame looks to drop lower than the bottom of the water table.
yea im with you… i can figure a rough estimate but i dont know what they have under there supporting the water trays. i built an air operated water table on my current setup that works amazing using a 55 gallon plastic drum. id really like to do the same on this table. just trying to see if the 55 gallon drums are gonna work or if i need to find/fabricate something else to store the water…
Just remember that the table holds 65 gallons so you will be 10 G shy of an empty table if you only use one drum.
yea i know. im already planning on 2 drums if they will fit…
Any update on this?
Depends somewhat on leveling feet. Ours are not extended that far and we have about 32" of clearance. There is no bracing that extends down from the water table except for the C-channel frame which extends 4" into the space under the table as shown below.
So none of the water table bracing sits below the C-channel shown above.
Hope that helps.
the way mines adjusted there is 2.5" clearance from floor to lower crossmember and 31.5" from floor to bottom of water table
Thank you! What are the inner dimensions in-between the rails length and width and what are the diameter of the feet?
If the bottom rails are 2.5" already that means I only have to build some 6" pedestals to clear my old harbor freight engine hoist legs. They measure 7.5"
You can also fab a new cross-member that is higher in the middle. That’s the plan for our shop. We’re going to mod the long side rail with some 1/4 plate. A few reinforcements maybe (though that’s already pretty stout). Will keep the work surface at a comfortable height for chasing tip ups and for cleaning.
