What are the maximum thickness you have been able to cut using the razorweld 45 for mild steel, stainless, and aluminum? If you happen to know the cutting parameters for those thickness as well it would also be appreciated. Thanks!
Well these are the official limitations in the manual.
If you do plan on cutting a lot of thick material with this machine the problem you’re going to run up against is your duty cycle.
There is a topic pinned in the forum with the razor weld cut charts that will show some of the maximum thicknesses from users.
