Is it possible to load a 1250mm (49.21") wide sheet on the CF Pro? I don’t need to cut that wide it’s just that standard sheet size here in Sweden is 1250mm (49.21"). It would be nice to just load a sheet without cutting it down
Yep it will fit
the measurement of the water table alone if 52"…the sheet fits…but you will not be able to cut that full width…just have to slide the sheet a bit
