If anyone is a shop owner and uses Mastercam i have a machine definition and control file and x8 post if you need one let me know.
Hello-
We just purchased the Langmuir Plasma table in and are using Mach 3 with LazyCam. I work at a prototyping shop in Anderson, SC and we use Mastercam 2019. I saw your posting about having a post, machine definition and control file. Not sure if I can import it and use it in 2019 but would like to try.
If you would mind would you email me those settings? My email is matt.talbot@ttigroupna.com
Thanks so much.
Matt Talbot
Lead Modelmaker
TTi
Hi,
If you could send me send me your machine def, control file and post for x8 i would greatly appreciate it. cobalt5150@att.net
Thank you,
Todd
Is this thread still active? I just got my plasma table today and I run mastercam 2018, does anyone have a post? My email is mcgn22@gmail.com
It’s for the 2 axis one not the pro but I emailed the files to you
The post files I have is for the 2 axis one but I emailed the files anyways. Enjoy
I use Mastercam and have learned it’s super easy and fast to design/change etc in design.
And convert to dxf and just import into sheetcam.
I draw in 3 different colors, I use green for outside cuts, red for inside cuts and yellow for no offset.
Sheetcam will import and use the colors to define the same offset to each color.
Just posting a different option than using cam side of MC
Was this still available? I could really use it for x5
