Im designing a cross and when i drew this it is multiple spline lines and trimmed circles. When i go to create the cut program i have to select each line. I know this will cause issues. How can i combine all of these lines to make one object? This is in Fusion 360
You just have a overrun or not connected line somewhere.
Iām having a very similar problem. I am trying to cut the tab out on the bottom of this holder. so the lines cannot be fully connected. but when I cut the file the tabs make 3 separate pierces and cuts when it should and only needs to be one. how do I make it so they combine for one smooth cut? using fusion 360.
BernzOmatic.dxf (32.4 KB)
