Upgraded my table with a machine torch t45m for powermax 45. For those not aware a member here makes these mounts I simply stumbled across his solution so I thought I would share. Install went smoothly and quality is top notch.
Picked a pair from Lil_Abners_Kustoms last spring. Best thing I ever did.
Quality and craftsmanship is top notch!
I highly recommend getting you a set.
This man takes pride in his work.
Thank you for the kind words gentlemen!
