Ok,
I know I’m gonna get the FNG answer, but here goes: I ordered the Langmuir machine torch dingus-end assembly with my Razorweld 45. The instructions are all for the hand-held torch and the wiring for the trigger switch firing bypass. Am I correct to assume that I can simply connect the Machine torch to the Razorweld45, and do not need to do any extra wiring as I would need to do for the hand-held torch?
That’s the setup I have, if you ordered it all from Langmuir, all you have to do is plug in the torch and torch fire/THC cables into the front of the cutter and you are good to go.
Bill, fantastic! Thank you very much!
Hmmmm… Someone else knows AvE ???
You know it! Uncle Bumblefrig has rubbed off on me… so to speak
