When I jog the table it will max the X (and Im assuming Y) axis out completely and only show 4" or so on my screen. 5"ish of travel on the table is only about 1 in mach
Scale reads +1.000 on all the axis’ in the mach controller
Again everything worked fine on my now defunct windows 10 laptop, I doubt its a hardware issue the table physically is moving fine.
The torch is also not firing. Im not sure if thats software or not. The machine itself does work when triggered manually.
In the Profile box on the lower right of the Mach 3 screen you should see CrossFire-v1.1, if you don’t then the wrong profile is being loaded and that would certainly mess up any operations. I’m not sure how to revert Mach 3 to asking about your config on startup, I’ve never selected “don’t ask…”
Reinstalling Mach 3 wouldn’t be terribly difficult…
