Do some of the Crossfires (original Not Pro ) Use Mach 3 and never versions of (original) use Firecontrol ?
Reason I ask is The Companies maintenance machine shop has a small Crossfire sitting in the Corner covered in stuff .I think its 1 -1/2 years old at most .
Although not my department anymore I would like to help out the new machinist get it up and running .
Just need to know whether he needs to load Mach 3 or Firecontrol
There is a description on the Langmuir product page that shows how to tell if the CrossFire is original (and uses Mach3) or a newer one. You would have to search the site, but it’s off of the CrossFire upgrade pages.
Thank you for pointing me in the right direction I found the info
Under “Support” “Should i use Firecontrol
There is a picrure showing the 2 different comtrol boxes…a quick telltale is Mach3 has green around the USB port Firecontrol is Red
Wow this is no where. This is good info i almost burn down my machine langmuir needs to get there stuff in the ball. Good info herr with the red and green box
