Drawn and posted on sheetcam.
G code loaded into mach3
Torch will fire manually with trigger and also will fire with the torch toggle in mach3
When running g code the torch moves but doesnt command torch on during program run.
Yellow bar does not flash when running program
Switched post processor from mach3 -mach3 plasma and gained my m03 m05 codes
Mark your topic as [SOLVED] so it’s not a distraction to others.
