OP had a few different problems. I suggest that you tell us specifically what your problem is if you want help.
Seems I found the problem I can see the full design layout without the crossfire usb controller plugin but as soon as I add the crossfire plugin it will only show part of the design in mach3. Upon reading it is well over 500 lines of code so I assuming that is the issue. The only thing that doesnât make sense is it showing the entire design without the plugin.
Thatâs probably because there is no machine attached to run the design on. You can run the whole thing in simulation mode, but donât try to cut more than a few lines if youâre working with a demo version of Mach 3.
Yeah I have a total of 5100+ lines on the design and did have it plugged into the machine also.
hello did you figure it out im having the same issue?
