Is there a way to flip the drawing 90 degrees? I need to cut it in the X direction because it’s just shy of 24” long.
I don’t know if mach 3 can rotate the part but it’s done easy enough in fusion or what ever cad/cam system your using.
I believe in Mach 3 at the top the first “page” is program run; click MDI and select “local system rotated” and input the degrees desired.
