Hello all, I have a crossfire 2x2, all available add ons.
I put on limit switches, now Y axis moves forward with - not +.
How can I fix that?
How can I fix that?
Hey Jjfablab, I was also confused after installing the limit switches on my crossfire. However, it all works correctly and easily in the end. Here is what I learned:
Best advice I’ve heard in a LONG time! Cheers! ![]()
I don’t disagree with your steps but I found that I do follow the step to “home” then if I want to cut from the bottom left I trolley on down there. Set the work space to zeros and the program origin to lower left and that seems to work as well. They just need to agree.
This might also be a source of the problem as a kind “soul” (get it) helped me out:
Posted by @ds690
ds690There was some discussion in another thread about problems with a limit alarm when the torch fired. Langmuir made some changes to the firmware to fix the issue. The firmware number didn’t change, but you should re install the 1.3 firmware to get the updated version.
Thank you!
